need advice/ help change rear gear
So i have a 99 formula. and i just got a ta rear end out of a lt1 car with a 3.42 gear. im wondering what i need to do to get that gear out and in my rear end. or put my axles to the wheel on the old one.
In the long run, i need that gear to fit on my c6 zr1 5x120.65 rims. the adapters wont ever fit so i know the rims wont.
Turnerd89, You would get more help if you didn't use metric dimensions. 120.65mm=4.75 bolt circle. Check out this link from Mr. Shoebox about fitting late wheels on a earlier LT1 cars rearend.
http://shbox.com/1/4th_gen_tech2.html#wheel_mod
