Fuel question need help
Old 12-18-2013, 11:15 PM
402nebraskakid's Avatar
Default Fuel question need help
I'm currently dropping my fuel tank and ordering my fuel parts for my 5.3 swap. Question is since I'm running my stock truck intake do I use the corvette filter or not. And what an fitting do I use and size line.
Old 12-18-2013, 11:19 PM
i r teh noobz's Avatar
I believe the early truck rails were return style. If your rail has a return, you do not need the vette filter. If it is returnless, you'll need to run the vette filter.
Inlet is 3/8". Outlets are 3/8" feed and 5/16" return. All are standard GM quick-connect fittings.
Old 12-18-2013, 11:21 PM
It does have the return style so do I need a fuel regulator?
Old 12-18-2013, 11:57 PM
Or does the intake rails have a built in one
Old 12-19-2013, 01:46 AM
Mike_hawk's Avatar
If your fuel rail has only one line going to it (driver side) it is return less use the vette filter, if it has two lines, the regulator is built in to the rail. I'm pretty sure they are interchangeable, but I know on the return less its 3/8 for supply/ feed and 5/16 for return. Carquest or napa will have the fittings you need to connect to your sending unit. You may need a "fuel line repair piece( quick connect both ends 1' long pipe)"and a compression fitting but can use stock fittings after that.
Old 12-19-2013, 08:51 AM
ijimmy's Avatar
no you do not
Quick Reply: Fuel question need help
