What manifold is this?
Old 12-19-2013, 08:54 AM
S10Luke's Avatar
Default What manifold is this?
Does anyone know what exhaust manifold this is? I think this would be a good manifold for my S10 turbo 5.3 swap, since its hard to get something to fit on the drivers side with the steering shaft in the way.
Old 12-19-2013, 11:09 AM
Gingervitis Addict
slow67's Avatar
I'm pretty sure it's off an LS4 (front wheel drive 5.3L).
Old 12-19-2013, 12:23 PM
RonSSNova's Avatar
Yes, that's the front manifold from an LS4 fwd car
Old 12-19-2013, 12:48 PM
LS1Tech Sponsor
hellbents10's Avatar
That was my thought too, let us know how it fits on the drivers side if you try it.
Old 12-19-2013, 03:36 PM
stevieturbo's Avatar
The part number is on it
Old 12-19-2013, 04:25 PM
S10Luke's Avatar
Thanks guys, going to look for one and see how she fits. Ill be sure to post up some pictures when I try it out.
Old 12-19-2013, 08:07 PM
RonSSNova's Avatar
Where are you located? I have a spare
Old 12-20-2013, 09:30 AM
S10Luke's Avatar
I am located in Waco tx 76706
Old 12-20-2013, 09:39 AM
cyipher's Avatar
yup ls4, fits good in my mazda lol
Old 12-20-2013, 09:41 AM
cyipher's Avatar
sorry, for the huge pic if your gonna run the coil packs in the stock location youll need 90s for the plug wires at the coils
Old 12-20-2013, 12:15 PM
S10Luke's Avatar
In the original picture they show the coils are mounted down low by the oil filter
Old 12-20-2013, 02:30 PM
S10Luke's Avatar
Found some more pictures of this setup
Old 12-20-2013, 02:31 PM
ButchB's Avatar
I'm kinda new to turbos so excuse me if this is a dumb question but what effect does the distance of the wastegates from the turbo matter? Most people it seems put them as close as possible and thats what I had planned but I like the layout of yours much better.
Old 12-20-2013, 07:15 PM
oscs's Avatar
The wastegate doesnt have to be as close to the Turbos as possible. IMO the way its is placed in the mazda is perfect. The goal is to catch and re route as much exhuast gases before it hits the turbine.
Old 12-20-2013, 08:54 PM
ButchB's Avatar
Cool, thanks
Old 12-20-2013, 09:04 PM
LS1NOVA's Avatar
Thats my old setup. A cut down truck manifold actually has more clearance than a LS4. Ive used both in my car. LS4 is easier to just throw in and go though. Im working on an S-10 now and have been looking at options for a good setup for manifolds to market a single kit. Looks like an angle milled and cut down Trailblazer manifold should be ok running forward and down while clearing the steering.
The advantage to mounting the wg close to the turbo is you can get away with using one after the merge. Saves a little money and plumbing if you can get by with a 44ish mm unit.
Old 12-26-2013, 07:45 PM
S10Luke's Avatar
I would love to see pictures if you have tried this already thanks!
Old 12-27-2013, 06:17 AM
JAX04's Avatar
I loved that manifold when i used it, liked how it exited straight forward like that, we chopped it and truck manifold and built it up so they both exited straight forward. WOrked out real nice.
Old 12-27-2013, 11:42 AM
ws6ed's Avatar
On my 92 s10 i looked at that manifold. On the drivers side the steering shaft is so close to the motor it wouldn't clear without adding ujoints/relocating the shaft. Also the brake booster looked like it might hit as well but wasnt on the truck at the time. I ended up building a log style set up as i wanted to keep the inner fenders.
One trick to gain a little extra clearance is to get a steering shaft from a late 80s early 90s Jeep Grand Cherokee. It gets rid of the sloppy rag joint too. the ends are right you just have to shorten it about 2"
Old 12-28-2013, 11:24 AM
S10Luke's Avatar
Awesome! Yeah I already have the Grand Cherokee steering shaft swap, it does make quite a bit more room in there.
Quick Reply: What manifold is this?
