98 Vette LS1 in 91 240SX wiring for fuel pump
Old 12-19-2013, 08:01 PM
novaragtop's Avatar
Default 98 Vette LS1 in 91 240SX wiring for fuel pump
I'm so close. I have everything wired but the fuel pump. I used a Painless wiring harness for the 98 LS1 engine, and it has a fuel pump relay wired into the harness. I just need to find the correct wire to send the power to the fuel pump, and I can fire this bad boy up!! I know the location of the stock Nissan 240SX lower harness with the plug that has the Black/Purple stripe near the stock fuel pump relay in the engine bay, but research says to wire the ECU signal from the NEW relay to the White/Purple stripe wire for power supply to the fuel pump? Any one done this, that would be able to tell me where to find this wire, or the correct wire, if I'm wrong? Thanks for your helpful info!!
Quick Reply: 98 Vette LS1 in 91 240SX wiring for fuel pump
