Aem 320
Aem 320
I bought the aem intank fuel pump for my mustang all I need to know is what else do I need? Like fuel lines do I have to have a return and how do I mount it etc. any advice would help I have no clue on the fuel system
Old School Heavy
I am not familiar with that fuel pump, but since it os an in tank fuel pump, i will assume it is high pressure. If this is correct, run a 3/8 to 1/2 line from the tank/pump to the front. Locate your regulator right next to the carb. You can use the Holley 12-203bp regulator:https://www.holley.com/12-803BP.asp .
Run a return line back to the tank of the same size.
Make sure the return line feeds to the bottom of the tank so it does not aerate the fuel in the tank.
In-Zane Moderator
Factory EFI and se carbed tanks have them but they are small, too small for return systems. They do make a kit to return to the fuel filler neck that would be a decent option.
I have always dropped the tank and put a fuel line in the pumps place and mounted an external pump and if I went bypass, I ran the return to a T fitting that was between the tank and the pump. Works great.
Another option would be a Mallory 4309 regulator. It is sized to work with 110/140 gph free flow pumps, which my guess is what that AEM pump is going to flow. With that large of a pump you can get by with 3/8 inch line but Mallory recommends 1/2 supply and return lines.
http://www.jegs.com/InstallationInst...0/650-4309.pdf
https://www.holley.com/data/Products...7914-3rev6.pdf
they say their 110 gph free flow pump flows 70 gph at 9 psi while their 140 gph free flow pump flows 120 gph at 9 psi. They say the smaller pump need the BP regulator while the 140 gph pump needs a completely different part number.
That AEM pump flow 84 gph at 43 psi, which means it is probably somewhere between the two pumps listed. I couldn't find a pump curve table to know for sure, it might even be closer to the 140 gph unit. So while the smaller regulator might work fine, it isn't what Holley recommends for a pump that size.
Old School Heavy
You need to be careful. Carb pumps are typically rated at free flow while EFI pumps list the at pressure flow rating. If you look at the applications table in the instructions for the regulator you linked earlier
In-Zane Moderator
No, I would run your own 3/8 line as a return. Wether it is aluminum or whatever. That small line will not move enough back to drop the pressure to the desired amount. They make kits that return to the filler neck or you can run it wherever that is before the fuel pump if it is external.
