What injectors
Old 12-21-2013, 07:21 PM
vht
vht's Avatar
Default What injectors
2000 6.0 truck engine, 5.3 heads with 2.00 valves, port work, or 243's. 575 to 600 lift cam. What injectors will I have to upgrade to? Once I get the heads I'm going to call and get a cam recommendation, this will be a mostly street motor, turbo trans or glide, 3.42 gear. Also I guess I'll have to use inj rail spacers and deal with a different inj plug? I thought I may run upon a set where someone upgraded to bigger and better, so I'd kinda like to know what to look for.
Old 12-23-2013, 02:06 PM
FICINJECTORS's Avatar
we have a drop in (no adapters required) in 36lb that work well with heads/cam 5.3's
http://fuelinjectorconnection.com/sh...?productid=485
Quick Reply: What injectors
