Drive By Wire confusion
Old 12-22-2013, 07:32 PM
BoneStockWS6's Avatar
Default Drive By Wire confusion
So I'm messing around trying to get the idle below 1,000 rpm's using this Haynes/Chilton manual. I'm reading everything its throwing at me when I get to this note that reads:
Note: On 2000 and later models the throttle control system is electronic. There is no mechanical cable, but rather a throttle position sensor at the pedal and electronic motor at the throttle body.
Checking VIN's and all that technical data and I sure enough have a 2002 Trans Am WS6 with an LS1 w/T56 ... So why I have a throttle cable? Or is this manual confused? Any help would be great
Old 12-22-2013, 07:45 PM
jrpimp00's Avatar
There was never DBW on any Fbody's.
Old 12-23-2013, 04:53 PM
That's MISTER MODERATOR
Paul Bell's Avatar
All LS1 Camaros and Firebirds had cable actuated throttle bodies. The book you have is incorrect.
Old 12-23-2013, 09:24 PM
Moderator
jimmyblue's Avatar
Chitlins manureals have always sucked. Buy the Helm
set if you plan on keeping the car, you will not regret
the real thing.
Old 12-23-2013, 09:42 PM
sick_tight's Avatar
i believev it was a chiltins manual i bought that had 3 separate diagrams for XJ serpentine belt configurations for my 96 cherokee and none of them were what my 96 cherokee had.
those manuals SUCK!
Quick Reply: Drive By Wire confusion
