U joint help.
Old 12-22-2013, 09:45 PM
BrainFreezE's Avatar
Default U joint help.
So my u joint busted today.. a little confused on which U joint to get because I have a moser 12 bolt on my 2000 T/a so if I go to autozone and ask for a U joint for my 2000 T/a will it fit the moser 12 bolt or do I have to get a different size? hope you guys understand what I am trying to ask.
Old 12-23-2013, 08:47 AM
01ssreda4's Avatar
Your moser should have a 1350 joint. What DS are you running? Stock?
Old 12-24-2013, 06:17 AM
Thanks a lot man!! I swear I went to Napa , auto zone , pep boys nobody knows nothing. and they don't even speak English lmao I mean i'm Hispanic bro but c'mon
Old 12-24-2013, 07:21 AM
01ssreda4's Avatar
What just happened here......
Old 12-24-2013, 08:12 AM
1BAD98LS1's Avatar
Since your car didn't come with the 12 bolt its not going to do you any good to tell them to get you a u-joint for a 2000 t/a... The only thing they know how to do is type sh*t In the computer based on the model, year etc. of the vehicle you are looking up parts for. Most have little or no actual knowledge of cars lol
Old 12-24-2013, 08:13 AM
1BAD98LS1's Avatar
I think he got excited when you told him he needed a 1350 u-joint LOL
Old 12-24-2013, 08:59 AM
96lt4c4's Avatar
If you tell them you need a 1350 u joint they wont know what the hell you are talking about.
http://www.jegs.com/i/Spicer/094/5-1350X/10002/-1
Have them cross reference this part number.
Old 12-24-2013, 09:43 AM
ironmanLS1's Avatar
Are you using the stock driveshaft? If so you most likely need to get a Moog or Precision #447. This is a 1350 to 1344 conversion. If you had an aftermarket driveshaft made up hopefully they made it 1350.
Old 12-24-2013, 10:19 AM
01ssreda4's Avatar
^^Right that's what I was getting at but never got that far.
Old 12-24-2013, 05:29 PM
NOS LS1's Avatar
Default Solid U Joint
Go with a Solid U Joint without the Zerk Lube fitting. Solid U Joints are stronger.
Old 12-26-2013, 07:50 AM
I am using an aluminum drive shaft.
Old 12-26-2013, 09:24 AM
1997trans-am's Avatar
I have the same situation. Hard to find the proper strap kit for the u joint.
Old 12-27-2013, 07:46 AM
1981TA's Avatar
OP: was the ds bought at the same time as the 12-bolt, or is it the stock, factory ds? This may impact whether you need one of the special 1340/1344 conversion u-joints or a straight up 1350 u-joint
Old 01-24-2014, 10:54 AM
xampir12's Avatar
Having similar problem bought a carbonfiber shaft and the ujoints are larger then the yoke on the rear anyone know the conversion for this issue?
Quick Reply: U joint help.
