clutch question for ls1 z28
Here a newbie clutch question what is a decent clutch for little all motor set up with little spray. Is the ls7 or ls6 kit or just aftermarket stage 1 or 2 . Please let me know I haven't found a satisfying answer. I would lime experiences and input please
Everyone is going to tell you to go with Monster. Theres several other good ones out there that you can't go wrong with as well. More information on your car would help suggest the right stage and whatnot for your power level.
ok to badformulals1
ls1 with 243 heads, long tube, ory, 96mm intake man, 92 mm tb, custom 4 inch intake, torquer 2 cam, 100 shot nitrous when needed.
it daily driver drive on the street with street tires and on another set it has mt comps. when im going to race. but mainly it street driven to and from work and ive been to the track only 4 times this year
my slave/throw out bearing is leaking badly i have to fill res every 3 days. if im going in to remove the slave bearing lol. i want to do the clutch. i hear monster and ls7 but i wanted to go with a spec clutch, ive heard good reviews. but id like the ls1tech family opinion
I've had good luck with ls7 and monster lvl 2. Monster will say no nitrous with lvl 2. Never used spec. If you go with monster you definitely want the lightweight flywheel.
