Tsp ory touches floor pan, HELP!!! (with pictures)
Old 12-25-2013, 11:28 AM
ls1mustang00's Avatar
Default Tsp ory touches floor pan, HELP!!! (with pictures)
I am giving up on this ory and will probably be taking my car to a muffler shop,unless someone here knows what i am doing wrong. It just seems every way i try to put the ory it always touches the floor pan on the driver side. Please take a look at the pictures.
Old 12-25-2013, 11:33 AM
luigiandme's Avatar
I dont see pictures. Your best bet is just to keep all the clamps loose, wedge something between the pipe and floor plan to your "Preferred Gap" and then snug the clamps down and remove your wedged item. Works for me when a specified gap is needed...
Old 12-25-2013, 11:47 AM
Im having trouble with the pics and also realized i posted on the wrong section, but the problem is on the first pipe that connects to the header, it can barely go in, like if the header points towards the car a little
Old 12-25-2013, 12:52 PM
sepsis's Avatar
So it's not the ORY that's the problem, it's your header.
To post pics, just upload your pics to Photobucket, then in your library, copy the link under the pic you want to post, and paste it in the message box here.
Make sure to copy the link that has the [img] tag.
Old 12-25-2013, 01:04 PM
nathanWS6's Avatar
It's either your header or mostly you motor mounts need replacing.. That was my problem and once I switched them out to polys I had no touching problems at all.
Quick Reply: Tsp ory touches floor pan, HELP!!! (with pictures)
