No change in fuel pressure c5 corvette
Old 12-25-2013, 12:51 PM
Stroker450's Avatar
Default No change in fuel pressure c5 corvette
Started checking fuel pressure the other day after fuel filter change. Pressure is great just never changes at idle or at rpm. Regulator is on the rail I checked the vacuum line and never see vacuum on it at idle or up in rpm. When I apply vacuum to regulator it's self it starts to come down in pressure so I know it works. Vacuumed is pulled off of intake in front of throttle body. Any ideas why I have no vacuum ?? Thanks!
Old 12-26-2013, 07:32 AM
Ollie8974's Avatar
Originally Posted by Stroker450
Started Vacuumed is pulled off of intake in front of throttle body. Any ideas why I have no vacuum ?? Thanks!
Attach the vacuum line after the throttle body.
There is no vacuum before the throttle body.
Old 12-26-2013, 10:37 AM
Stroker450's Avatar
It's the stock location ? Is it not supposed to be there ?
Old 12-31-2013, 01:21 AM
joecar's Avatar
If you have a 1997/1998 Y-car then the FPR is in the fuel rail and the reference hose open to BARO/atmosphere... (i.e. it is un-referenced);
this is how 1997/1998 C5 came from the factory; 1999+ Y-car and 1998-2002 F-car all have FPR in fuel module in tank (with reference open).
Quick Reply: No change in fuel pressure c5 corvette
