Spark plug wires for distributor swap?
Old 12-25-2013, 10:54 PM
93hatch's Avatar
Default Spark plug wires for distributor swap?
Does anyone know of a premade set that will work?
these maybe?
http://www.summitracing.com/parts/acc-9060c/overview/
Old 12-26-2013, 02:03 PM
Project GatTagO's Avatar
Received 1,393 Likes on 879 Posts
these maybe?
What distributor are you using? You will want to match the terminals on that side to whatever is on the distributor. Once you figure that out, look for any set that is designed for a small block Ford.
Andrew
Old 12-26-2013, 06:31 PM
93hatch's Avatar
the regular MSD that is recommended for the kit. You sure a mustang set will reach?
Old 12-26-2013, 06:45 PM
No, I am not sure, but why wouldn't it? The LS engine has the exhaust set up just like a SBF.
Andrew
Old 12-26-2013, 09:13 PM
v8sten's Avatar
MSD makes a long make your self kit for the ls motors. i forget the part number though. maye a 351 windsor set might work
Old 12-28-2013, 02:46 PM
93hatch's Avatar
Andrew
yeah but the distributor is in the timing cover, its pretty far forward compared to a sbf
Quick Reply: Spark plug wires for distributor swap?
