V6 cooling fans same as LS1?
I'm looking for a set of dual electric fans for my '08 TrailBlazer SS. PCMForLess has a conversion kit that will work with LS1 F-Body fans. I've found a couple sets of dual fans on V6 Camaros at a local junkyard. Are these the same as the fans on an LS1?
From my old research of swapping a ls1 into v6 fbody.
I found this site. http://www.tacreationsusa.com/3_4_3_8_v6_to_ls1.htm
According to this chart, you can use 1996 + v6 fans assembly in ls1car.
This however doesn't mention the connectors.
Unless someone can elaborate / correct me?
