What type of heat shield material is this?
What type of heat shielding is this? I see that the material can either be inconel or aluminum. I would like to purchase it in sheets to be bend, shaped, etc.
I know APS had them on their turbo kits. It seems like this material is big in the UK and AUS.
I also know that it can be referred to as "Double Wall Aluminum" or "Embossed Aluminum"
Any help?
Any help?
Tons of manufacturers out there make heat shielding kits.
http://www.summitracing.com/search/p...at-shield-kits
http://www.jegs.com/p/JEGS-Performan...82211/10002/-1
http://www.jegs.com/p/DEI/DEI-Heat-S...98875/10002/-1
Use these two links, there are tons of different products.
http://www.jegs.com/c/Exhaust-Header...10261/10002/-1
http://www.summitracing.com/search/d...eat-protection
The only thing i can see that may be close is the DEI floor and tunnel.. Link below:
http://www.summitracing.com/parts/dei-050503/overview/
The material i am looking for is hard. Its what OEM's use for heat shielding as well. Often pressed into shape.
