Twin Turbo LSx 6.0 Notch Project
Old 12-27-2013, 01:32 PM
baggedsvt's Avatar
Default Twin Turbo LSx 6.0 Notch Project
Started thread in Hybrid but figured I would link here as well. https://ls1tech.com/forums/conversio...h-project.html
Old 01-04-2014, 07:09 PM
baggedsvt's Avatar
No updates in a while car at at my buddys paint shop getting new hood painted and fenders and bumper blended plus some speed holes in bumper to help with air flow to intercooler. Also wing and some under hood pieces being painted.
https://lh4.googleusercontent.com/-j.../IMG950775.jpg
https://lh3.googleusercontent.com/-c.../IMG959473.jpg
Old 01-05-2014, 08:27 PM
xsivpwr's Avatar
Looks good. Keep the updates coming.
Old 01-05-2014, 08:39 PM
baggedsvt's Avatar
Picking car up from painter. Bumper is just thrown back on for transport needs aligned properly but fit and finish is great and the paint blended in very nicely.
Old 01-05-2014, 08:41 PM
01 WS6 6.0's Avatar
Subbing for this one Im doing the same with my coupe but big single. Is that the holley high ram?
Old 01-24-2014, 09:50 PM
baggedsvt's Avatar
Yes the Hi Ram and it fits the description for sure.
Old 03-28-2014, 11:50 AM
baggedsvt's Avatar
Been a wile for updates but it has been the small things. Fuel lines, vacuum lines, boost lines, spark plug wires and such. It wont be too long now. All that is left is adjusting shifter cable, putting lower rad hose on, putting fluids in and then wiring everything up. here are a couple pics.
baggedsvt's Avatar
Some more progress. Vaccuum lines all ran with 1/4 dot line and fittings are push lock. Oil feed and drains run. Breather lines run and tanks mounted. Fuel lines all hooked up to regulator. Plug wires and dei heat shield. over 1000 dollars in new fluids are in. Little decal added to front bumper to make people mad lol.
Pic without coil covers. I could never leave them off looks so ugly without them.
Old 03-28-2014, 12:29 PM
WS6HUMMER's Avatar
Nice looking build!
Old 03-28-2014, 01:29 PM
V-seriesTech's Avatar
Badass
Old 05-10-2014, 08:51 PM
baggedsvt's Avatar
Old 05-11-2014, 07:30 AM
Guard dog's Avatar
Looks like it was meant to be there. Great attention to detail.
Old 05-11-2014, 09:50 AM
I8URLS1's Avatar
What rpm did the power start to fall off? You think that is due to the cylinder heads?
Old 05-11-2014, 03:39 PM
ltcamaro17's Avatar
Thumbs up
very nice build!
Old 05-11-2014, 07:38 PM
baggedsvt's Avatar
Cam selection. Its a baby cam really. Cam is the single determining factor in my power curve as these heads ind intake should have no problem at 7200 if I wanted to go there.
Old 05-11-2014, 09:33 PM
I8URLS1's Avatar
Ok good deal, I should have enough cam to carry the power and out a little higher. Really good numbers man, makes me want to get mine done so badly!
Old 05-11-2014, 09:36 PM
ls1CANTU's Avatar
This is a beautiful car and combo too.
Old 07-04-2014, 01:45 AM
baggedsvt's Avatar
First we gave you the build and you wanted more. Then we gave you dyno numbers and you wanted more. Now I give you a 8 second Notch first night at the track. We were just working off the footbrake and E-brake to launch. First pass was 17lbs, 2nd was 20lbs, and the last was 21.5 lbs. Very happy with the results.
Video shot in the crowd pulling a wheel
https://www.youtube.com/watch?v=CXeu...ature=youtu.be
Old 07-04-2014, 02:02 AM
Moderator
denmah's Avatar
damn incredible, i thought that in a twin setup these things would really shine
Old 07-04-2014, 05:37 AM
9 Second Truck Club
stock48's Avatar
Good work for 1st time out guys! There is easy 8.50's or faster with that same power and just a good launch.
Looks like the early power pk really hurt it thru the traps at 7500 RPM....
Quick Reply: Twin Turbo LSx 6.0 Notch Project
