EFI connection two piece billet timing cover.
Maybe this question has been posed before, but I don't remember it. I was thinking last night about the billet timing cover that EFI offers and wondered if they have ever considered building a two piece billet cover for the LT1. It sure would make it so much easier to change out cam profiles. Just a thought, anyone is welcome to comment, but I hope EFI connection will visit and provide some input on this subject.
Thanks
Thanks
LS1Tech Sponsor
I am sure Mike will chime in. As stated above there probably is not enough demand for such an item. Especially when a custom CNC piece like that would most likely cost well over $300.
Not saying that it is not a great idea, it just boils down to not enough demand.
__________________
Standalone LS Swap Harnesses IN STOCK!
LSX, LTX Stand alone swap harnesses. S10 LSX conversion PLUG AND PLAY harnesses, 24x conversion PLUG AND PLAY harnesses. LT1 to LSX PLUG AND PLAY Harnesses.
sales@bp-automotive.com
www.bp-automotive.com
1-888-467-4491
1-888-467-4491
I would think, given the accuracy needed in lining up the crank seal, Optispark seal, and water pump drive, it would be almost impossible to make a multi piece cover that would properly line everything up. Keep in mind, with the standard SBC, the only thing that relies on the timing cover for alignment is the crank seal.....
Then there's the limited market, and potential costs.
There's not much margin in making a billet timing cover at $350-400 each. Our cost for the block of aluminum alone is $100. Add to that a full day of machine time, someone to watch the machine, replacement tooling, fixtures (and fixture service), anodize, and so on. A two-piece cover will require an additional piece of aluminum, more fixtures, more tooling, more machine time, a gasket (that doesn't exist), and so on.
I think the show-stopper may be the crank sensor boss. The front of the cover would have to be removed all the way down through the crank sensor boss. It may not be possible to separate the timing cover...I'd have to review our solid model.
If we had a commitment of maybe 10 timing covers at $450-$500 each, we could look into it.
I would pay more for that option.
Yes. Our new timing cover with cam sensor boss requires our double row timing set with 1x cam signal. No aftermarket double row timing set has provision to drive the upper LT1 water pump gear.
Aaron had a little time to brainstorm while running the mill today, so he came up with this idea.
We are not so sure the cam sprocket will have clearance to be removed. We could move the face of the timing cover away from the engine for additional clearance. The LT1 water pump provides generous clearance for this.
LS1Tech Sponsor
__________________
1-888-467-4491
1-888-467-4491
Looks good, I'll be keeping my eye on this.
S10 Wildside, This is exactly what I had in mind! I'm very interested in this two piece cover. Hopefully we can generate enough interest to make sense of it for all parties (buyer & seller). I for one would certainly pay for this item. I'm looking to upgrade my current GenIII optispark, Delteq, and MSD twin coils setup. I'm really wanting to move into your 24x setup and would like to have this two piece billet timing cover option.
I will be watching this closely.
PS: Also on a side note, would I be able to run a double roller with a setup like what we are discussing?
