LS7 clutch require stepped flywheel?
I broke the center part of the disk of my clutch when the rear axle blew up.
The guy that had my '98 LS1/T56 before me told me it was an LS7 clutch he put in before I got it.
Thinking I was saving myself some hassle I thought I would just get the same for a replacement, so I ordered a LS7 clutch kit off the web.
From what I can tell, the new LS7 clutch I got requires a non flat flywheel with a step down for the disk, and has 3 locating pins.
Is this correct?
I think that the clutch I broke is probably a LS6 clutch. The disk measures about 11.4 across and the flywheel is flat and has 2 locating pins.
Is there a place I can order just a new disk that will allow me to just re use the pressure plate?
Motor is stock, and I don't want to mess with the hydraulic stuff. Just want to get this back on the road.
Any other suggestions would be welcomed.
Is this correct?
It came with just the Pressure plate and disk.
I found a kit online that includes the same flywheel, PP, and disk that I took out, but my flywheel is in good shape and I already had it surfaced too.
Thanks nascarnate.
Thanks nascarnate.
