Anyone done a T56 or T5 trans on a LS Fox?
I've done a couple LS foxes but always auto. I found a cool Fairmont wagon that's an original stick car.
Trying to figure out if T56 shifter ends up in right place or adapters to a 5 speed
A T56 with fbody tailshaft and shifter sits a little farther back using the swap kits but you can make it work. I saw one swap where a Cobra T56 tailshaft was swapped on and the shifter fit nicely in the fox chassis.
A T5, or Tremec 3550 / TKO can be done you need to search around the the bell housing to adapt and them make a clutch work.
