To manifold wrap or not? To wrap the hot side or not?
Old 01-01-2014, 02:56 PM
Boosted Firehawk's Avatar
Default To manifold wrap or not? To wrap the hot side or not?
How many guys wrap their manifolds?
To leave them alone or wrap them up?
ANy pix of others doing this?
ANY benefits at all besides the WOW factor?
Old 01-01-2014, 03:06 PM
coolmanvette75's Avatar
On my car I'm just going to ceramic coat the manifolds and DEI wrap the merge pipes and downpipe...
Old 01-01-2014, 04:31 PM
zapp109's Avatar
I wrapped mine but sorry dont have any good info figuring the car has yet to run. It was a little bit of a pain in the ***. Probably used 20 ft of wrap per manifold (1 layer) and you have to keep pulling it through if you want to keep it 1 piece like i did.
Old 01-01-2014, 05:19 PM
a98ws6's Avatar
I was wondering the same. Is coating enough or just wrap or both?
Old 01-01-2014, 06:16 PM
Slow94Formula's Avatar
I just coated the manifolds and wrapped the hot side. I have nothing to compare to as far as how much it helped compared to nothing, but it doesn't just seem like a heat wave comes out when you open the hood after the pass, so I'm going to call it good enough.
Old 01-01-2014, 06:17 PM
samdogmx's Avatar
I wrapped mine. If you shoot them with a temp gun they are about 100 degrees cooler right after a pass than they were b4 I did the wrap. Some guys swear it helps with spool up but i didn't see much difference.
Old 01-01-2014, 06:51 PM
02sleeperz28's Avatar
Hmm, ok. Cool.
Old 01-01-2014, 07:10 PM
Tally TransAm's Avatar
i wouldnt wish wrapping the manifolds on my worst enemy, the cross over and downpipes are bad enough. i just had mine ceramic coated
a couple of my wrap jobs (and manifolds):
Old 01-01-2014, 07:14 PM
Heavy H.P.'s Avatar
So no one has seen any gains at all from doing this?
Old 01-01-2014, 07:33 PM
zapp109's Avatar
LOL it is fun, I did mine dry and had fibers flying as i was pulling it thru was itching like crazy. If you do wrap it do yourself a favor and get a 50 ft roll or even 25 ft i used a 50 and the first wrap took a while pulling the 50ft thru.
Quick Reply: To manifold wrap or not? To wrap the hot side or not?
