Got my dyno numbers
Old 03-10-2003, 08:10 PM
N2O4YOU's Avatar
Default Got my dyno numbers
Well, got my car from Speed Inc. today. NOT GOOD!
They called me up and said it wasn't making power, so they put in a new cam thinking it was a bad grind. New cam, same numbers. They said everything checked out ok but just not good numbers. They seemed cooperative and i feel they did a good job.
Hers the results:
320.4 RWHP & 344.5 RWTQ
They said the exhaust is not helping and I could use a ported TB. But I will be putting on true duals first. The RASP is terrible at 2200RPM
Old 03-10-2003, 08:33 PM
BIGBOS's Avatar
Default Re: Got my dyno numbers
Those #'s are defiently low, what was the AFR on the dyno, and knock..
Most average bolt on cars make that kind of power...
Old 03-10-2003, 08:41 PM
Chad00ws6's Avatar
Get rid of the flowmaster <img border="0" alt="[shoot]" title="" src="graemlins/gr_guns.gif" />
I put in dual cutouts in my y-pipe even though all I have is a flowmaster <img border="0" alt="[barf]" title="" src="graemlins/gr_barf.gif" /> no cats or anything I gained 32rwhp and 42rwtq when I opened the cut outs.
Granted I have a larger motor that likes to breathe but that is just outrageous loss from just a damn muffler. <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Old 03-10-2003, 08:59 PM
N2O4YOU's Avatar
How do i post my dyno sheet?
Old 03-11-2003, 01:31 PM
Constrictor 98TA's Avatar
In order to embed the image into a post, it must already be publicly available somewhere else on the internet. Once you do that, you put in the whole link to the image in between <img> and </img>. Replace the < and > with [ and ] for it to actually work correctly.
If you don't have webspace, you can register at a free picture hosting place like Webshots, or Imagestation and just post a link to the picture. These services do not allow you to embed images though.
Old 03-11-2003, 04:32 PM
NHRAFORMULA00's Avatar
Your torque numbers are 10 lower than mine but the hp is like 40 down from mine same cam.im running hooker lt ,no cats through the stock muffler-360hp. are you runnig cats with that exhaust? just cant figure why your hp is so low!where did it peak at, like 6200-6300. just trying too help you out, those headders should flow real close to what i have,but with cats maybe 10-15 lower.
Old 03-11-2003, 05:53 PM
Slow Z28's Avatar
1st try at dyno posting.... <img src="http://www.brewcitymuscle.com/forum/attachment.php?s=&postid=7126" alt=" - " />
Old 03-11-2003, 05:58 PM
Slow Z28's Avatar
so peak hp is at what, 5200-5600 rpm? that is really low for a cam. anybody got thoughts on this? isn't the cam he chose, basically a TR224? would any advance or retard ground into the cam without installers knowledge affect the dyno like this?
Chris
Old 03-11-2003, 07:17 PM
N2O4YOU's Avatar
i read in the cam paperwork that comp put in 4 degrees advance on some of their cams(ground in )
Person(pretty good mechanic from my experiences w/ him) said by looking at dyno it screams timing off. They said they degreed the cam.
Old 03-11-2003, 07:44 PM
Slow Z28's Avatar
Yoosof (YOOFORMULA) hadthe cam in a little off in his car, so his hotcam/mac header combo only put out 325rwhp and we wll couldn't figure it out. so, he tore his apart and ended up finding out he had put it in advanced. he didn't have any tuning either. anyways, fixed that and car picked up. but if they redid the install, and with as many cars as they have installed cams in, it's hard to think that they did something wrong, unless it was wrong from the manufacturer.
Chris
Old 03-11-2003, 07:47 PM
N2O4YOU's Avatar
Your probably right. Maybe i should try to retard somehow a little to see if it picks up.
Anyone have any suggestions other than degreeing the cam
Old 03-11-2003, 10:30 PM
LS1Tech Sponsor
Slowhawk's Avatar
Looks exactly like a cam timing problem or you are getting serious knock in the high rpm.
Old 03-12-2003, 02:57 AM
Fenris Ulf's Avatar
The cam is peaking WAY too early. Something is definately not right with that setup.
Old 03-12-2003, 06:01 AM
N2O4YOU's Avatar
Speed Inc. Said they got no knock retard. Im going to get the cam dgreed to find out for sure if the timing is off
Old 03-12-2003, 02:43 PM
The Juggernaut's Avatar
What's confusing to me is the peaks and
you make 24 more rwtq then hp.
Usually with that cam,torque is lower than Hp.
That looks like my stock internal dyno graph,
only lower and more jagged.
Very confusing.
Old 03-12-2003, 08:13 PM
N2O4YOU's Avatar
Checked all the wires, 7 plugs(that i could get at), changed the fuel filter. Still no go. I will try stock MAF too.
Drove hard a couple times today and no guts. Seem pretty close to what it was before. Something has to be up.
Want to check degree on cam. 5 or more people have told me that my dyno screams a timing problem. Can someone tell me how to do this.
<img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" /> <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old 03-12-2003, 08:18 PM
Hp Joe's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Z99LS1:
<strong> Well, got my car from Speed Inc. today. NOT GOOD!
Hers the results:
Relax buddy everyone can not make 400+ hp,dyno Numbers dont matter when you get to the track drive the car and see how wellyou can do
They said the exhaust is not helping and I could use a ported TB. But I will be putting on true duals first. The RASP is terrible at 2200RPM </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">
Old 03-12-2003, 08:34 PM
N2O4YOU's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Hp Joe:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Z99LS1:
Hers the results:
They said the exhaust is not helping and I could use a ported TB. But I will be putting on true duals first. The RASP is terrible at 2200RPM </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"></strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I noticed the Speed Inc. Link in your sig. Do you work there? Did you work on my car?
