T56 Mainshaft roll out spec.
Old 01-02-2014, 04:23 PM
elesquan's Avatar
Default T56 Mainshaft roll out spec.
I have been looking to see if there is a maximum allowable roll out specification for the main shaft, and have not found one.
My Main shaft has about .003 roll out near the output end, and thought it would be worth asking before I begin assembly hopefully tonight if the parts make it from Tick.
Anyone checked this and found a specification?
Thanks!
Old 01-03-2014, 09:00 AM
elesquan's Avatar
I am very surprised that none of you very experienced people know the answer.
Guess I will put it together and hope for the best, thanks!
Old 01-03-2014, 01:22 PM
calhoon's Avatar
[You mount the shaft between the two conical dimples ate the ends of the shaft( centers) and you measure runnout on the ground journals. The max should be .05mm / .002 inch.B][/B]
Old 01-03-2014, 01:56 PM
elesquan's Avatar
Thanks Calhoon!
I will bring the main shaft to a lathe and check it that way, I was just resting the main shaft on V-Blocks in my garage..
Love smart people who are willing to share information
Quick Reply: T56 Mainshaft roll out spec.
