Are the 80lbs/hr Ford racing injector any good
Ford Racing High-Flow Fuel Injectors M-9593-LU80 (copied off summit racing)
Is this a good injector? E-85?
Going on a 5.3 w/ GT-45.
Can get brand new for $200
What you guys think?
Thanks
Thanks
Where are you getting them for 200?
They aren't bad injectors. I don't know if the length of them is the same as our injectors so you might have issues with the stock rails if they are too short.
80 lb/hr, single-hole, high-impedance fuel injector with USCAR electrical connector
Single cone spray pattern
Original equipment on supercharged FR500CJ Cobra Jet
INJECTOR NOTES:
M-9593-LU80*
Suggested Retail Price
$519.00
Sold in Units of:
Eight Pack (8)
If they were take-offs, they are probably cheaper.
INJECTOR NOTES:
- Medium length injectors are for use in GT500 or Ford GT. We also use the MU32 in our 3v supercharger kits.
- The long injectors are the more common length and are applicable to all non-GT500 Mustangs since multi-port injection was introduced
- Wrong electrical connector for your application? Try our M-14464-A8 Fuel Injector Adapter Kit
- Need help determining which injector you require for your application? Refer to EFI Tech Tips
- The USCAR connector is sometimes referred to as EV6, which is a Bosch term for the generation of injector.
- Jetronic is the older style connector, sometimes referred to by the Bosch generation EV1.
- Neither EV1 or EV6 is technically correct because those generations of Bosch injectors could come with either connector. However most EV1's commonly seen use the Jetronic connector and most EV6's use the USCAR connector so it's easy to see the connection.
M-9593-LU80*
$519.00
Sold in Units of:
Eight Pack (8)
