turbo manifold
turbo manifold
Sorry if this has already been talked about but I searched and didn’t see anything on it. My question is there a distinct benefit on running a custom set of steel manifold(s) vs the reversed truck manifolds. Reason I ask is because I was looking at a set of customs ones but they’re going to run me $1600-2200 vs having the truck ones cut and welded (sure I can get it done for $400). Or is it just a cosmetic thing that looks nice.
Tubular manifolds can see benefits, but a lot will depend on your goals.
Plus most tubular manifolds will restrict plug access. Maybe a small point, but I'd hate to have to change plugs on some of them !! That would be enough to sway me from some designs.
Here's a thread asking about some shorties.
http://www.camaro5.com/forums/showthread.php?t=333810
just use truck manifolds or use the hooker smooth looking manifolds like I did. you will be fine. I seen a Camaro make 1279 whp with manifolds. if I can find my camera ill post the vid.
