question about transmissions
Old 01-05-2014, 01:42 AM
chopperdave90's Avatar
Default question about transmissions
did they use different automatic transmissions in 93 and 95. am i gonna have trouble putting my tranny from my 93 in my 95.....maybe pcm trouble????
Old 01-05-2014, 07:29 AM
That's MISTER MODERATOR
Paul Bell's Avatar
Yes, yes and yes.
Old 01-06-2014, 09:37 AM
93M6Formula's Avatar
The '93 Auto is a 4L60 which is basically a 700R4. Non computer controlled.
'94+ is a 4L60E which is computer controlled. But they all don't interchange either due to electronic differences.
Old 01-06-2014, 05:23 PM
duh
duh's Avatar
Simple answer is yes you will have problems. Lots of them. You're better off finding a 94+ trans and starting there. The 93's are a bastard year and have a lot if little differences from even the 92's. Save yourself some headaches.
Old 01-06-2014, 06:10 PM
lt1-xjs's Avatar
A few major differences
1. You'll need a 1993 throttle body to connect the t/v cable
2. Need to locate the wires from the brake switch for the tcc lock up.
3. May have to change the tail shaft housing and add a reluctor ring for the speedo to work, I'm not sure on this.
Other than that it should bolt right in.
Old 01-12-2014, 11:50 AM
96TransAmboosted's Avatar
Do research and you wont have any issues, they sell a vacuum kit for those trannys that does away with tv cable. tail shaft should be the same and uses the same cross member. they also sell a tcc lock up kit thats universal.
Quick Reply: question about transmissions
