346 N/A Injector Size??
Old 01-05-2014, 09:23 PM
adamc85's Avatar
Default 346 N/A Injector Size??
346 LS1
238 242 @ 108lsa
241 CNC ported, 0.60" decked heads
11.27:1 CR
Lunati Dual Valve Springs
Morel "Street" Tie Bar Lifters
Eagle steel rods
Mahle -4cc pistons (wrong choice.. I know.. )
Edelbrock Super Victor Manifold
Edelbrock 4-Barrel Throttle Body
Wanting to spin it to 7200
I need to know what size injectors. But all calculators I come across need a HP figure, well I don't really know that either...
Fuel will be one of two choices
A) Pump 98 octane
B) E95 race fuel
Obviously injector sizing will vary depending on the fuel type. Can you give injector sizing for both fuels?
Thanks!!
Old 01-06-2014, 11:46 AM
josh414's Avatar
if you can make 1.5hp/cid which is not unreasonable figure 520 more like 550 hard to say with out knowing what your heads flow. At 550 apx hp I would go with 42lbs injectors e85 25%-30% larger
Old 01-06-2014, 04:03 PM
adamc85's Avatar
Thanks, the heads flow 280 intake / 243 exhaust
Old 01-06-2014, 06:30 PM
josh414's Avatar
you should be right in the area as I stated as far as hp
Quick Reply: 346 N/A Injector Size??
