fast xfi dry nitrous
Old 01-06-2014, 12:03 PM
josh414's Avatar
Default fast xfi dry nitrous
does the power adder function add fuel to the base table or does it switch from the base table to the power adder table. IE does one need to include the required NA fuel+nitrous fuel or just the added fuel required for the nitrous. Im just not clear on if it is additional or total fuel.
Old 01-06-2014, 03:33 PM
ATVracr's Avatar
Pretty sure the adder just puts it on top of your fuel table.
We had always run ours in exculsive where you tell it the total amount.
Seemed easier that way but both will work just fine.
Old 01-07-2014, 08:16 AM
Dynospeed's Avatar
Its a adder table just for the nitrous. It will add fuel on top of the engines fueling table.
Old 01-16-2014, 10:23 PM
josh414's Avatar
Thanks
Old 01-17-2014, 02:12 PM
ATVracr's Avatar
How much are you spraying?
We could probably give you some good ballpark numbers to add fuel wise.
Old 01-18-2014, 06:42 PM
SMITH's Avatar
It can work both ways. It can add fuel on top of your base table or they can be used as exclusive tables and will ignore your base table.
Old 01-19-2014, 12:33 AM
josh414's Avatar
Plan to start small. id like to run 100 check things over then150 make checks then finish with 200. I see in the software that there are both options as you have stated.
Quick Reply: fast xfi dry nitrous
