Radnom Clutch Pedal Engagement Point. HELP!
For several years my clutch has engaged at random points throughout the clutch pedal stroke (sometimes the pedal is near the floorboard, other times it's almost all the way up). COLD WEATHER makes the problem much worse.
After I noticed the problem, I replaced the OEM master cylinder with one from AutoZone (not the best, I know), and I replaced the clutch, flywheel, slave, etc. with a Monster Stage 2 package.
I'm having the exact same problem with the Monster clutch as I was with the stock clutch...the engagement point on the pedal is all over the place.
No fluid is leaking, as the master reservoir has remained at the same level for several months.
Any ideas what could be causing this?
SNL - Clutch fluid is DOT 3. I don't have headers, and all factory heat shields are installed properly. Also, the problem happens even when the engine has just been turned on. Thus, I don't suspect it's the fluid boiling (which is what I assume you were wondering about).
