Tb for holley hi-ram efi
Looking to get tb ideals for holley ht-ram efi manifold. Don't want to spend $500+ dollars on holley tb. Will a stock style tb work would like to make 1000 whp at around 20psi of boost
engine spec.
Ly6 stock
ls9 head gaskets
ls7 lifters
comp rocker upgrade
borg wanger s480
ls9 cam and valve springs
holley hi-ram ?
Arp head studs
holley hp efi
holley 3-bar map
tea ported heads
engine spec.
Ly6 stock
ls9 head gaskets
ls7 lifters
comp rocker upgrade
borg wanger s480
holley hi-ram ?
Arp head studs
holley hp efi
holley 3-bar map
tea ported heads
Im going with the holley hi-ram as well, going with the 92mm opening. I will be a running a nick williams because from past experience the FAST sticks and hangs up therefore causing tuning issues.
a buddy of mine is using one of these cheap copies of a FAST 92
Godspeed SBC GEN III Ls1 Ls2 Ls6 92mm CNC Intake Throttle Body : Amazon.com : Automotive
