How much will the stock bottem end take?
I'm doing a build up, with a nice Head and cam package and some minor bolt on's but before its said and done... I'm shooting to get some high to mid 11's all motor. I was just concearned about the bottom end. I dont want to build a car that cant take the power so I figured I'd find out how much the stock bottom end will take before i need to worry.
Short answer: more than you're going to throw at it, as long as you don't plan on revving too high.
I don't think a h/c will outgrow your bottom end. Depending on which cam, you will probably be less than 450 RWHP. You'll have to worry about your tranny (A4)/clutch(M6) and rear first.
Mike Brown's Twin Turbo CE was running 9.85 @137 stock bottom end, what about 750rwhp give or take 50...ran over a year with no problems...when he finally pulled it apart to install forged parts, it showed no wear or tear...
Originally Posted by NataSS Inc
I am at 430rwhp through a moser "9. That puts it at about 525 fwhp and so far *knock on wood* no signs of even phasing the bottom end.
Originally Posted by JZ'sTA
I say you can even go 6800 without any problems. The botton end is very strong.
The next week I got the car shifting right and made 4 passes including a personal best. However, I started up the car a few days ago and at idle a very audible knock could be heard. Putting my hand on the water pump, the knock was very noticeable. I'm all freaked out that I spun a rod bearing that night it was shifting at 6800.
Is that even possible, to damage a rod bearing but then run 4 passes a week later including a personal best?
Pewterz28- Whats up man? Hate to hear that about your car!
*As for what I've been told, alot of guys have told me to just run some APR rod bolts in a stock bottom end and it should be good for 6500-7000 runs. I'm not too sure about the high end of that (7000rpms) but I know I won't be scared to shift it at 6500-6700. Good luck with it all!
IMO, I've been fairly conservative, always setting my car to shift under 6600 and never having my rev limiter higher than 6800. I have the rev set at 6650 now but I am hitting the rev limiter on my shifts so I'm either going to have to lower my shifts or raise the limiter. First I need to find the culprit of the tap though. I'll look at it some more today at lunch, hopefully it is something simple.
I don't see why not. Hundreds if not thousands on "the boards" have been doing it. Just don't spin too high. I don't know what that number is and it is probably different for each car. Too many factors; mileage, wear and tear, oil levels, etc. Just be as conservative as possible with your shift points without sacrificing too much performance.
Originally Posted by Ohmyneck
So basicaly if I go with a H/C package and a 12-bolt my bottom end should hold up just fine? I'm shooting for some mid 11 second times without any nitrous.
