Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
pro 4.29 gears for 9"
Old 01-08-2014, 10:17 PM
dezlfrek's Avatar
Default pro 4.29 gears for 9"
Category: Drivetrain
Price: $200
Location (State): CA
Item Condition: Brand New
LS Engine?: Non-LS Part
have some pro 4.29 gears I pulled out, very low miles, like less than 250. has the aluminum bearing cover with it, bearing, shims, and pinion nut all inctuded.
Old 01-09-2014, 05:12 PM
ctjohns's Avatar
What brand are they, any part number. Thanks
Old 01-09-2014, 08:23 PM
dezlfrek's Avatar
Richmond, I can send you pictures and ill look for part numbers for you
Old 01-09-2014, 08:29 PM
dezlfrek's Avatar
GF9-429-PRO 30-7 USA
that is on the ring gear, pinion only has 4.29 on it.. has bearings still on the pinion and nut with strange aluminum bearing cover also.
Old 01-10-2014, 06:16 PM
ctjohns's Avatar
Is that a big or small pinion? Any part number on the aluminum bearing cover? Sorry for all the questions, just want to make sure it will fit my stuff. Thanks
Old 01-12-2014, 08:17 PM
dezlfrek's Avatar
this is a big pinion and cover.. the gears I replaced these with are the small so I had to use a standard steel cover(same bolt pattern/interchangeable) in this strange aluminum cover's place and also why you are getting the bearings and such still on the pinion..
Old 01-14-2014, 08:16 PM
dezlfrek's Avatar
ttt bump
Old 01-15-2014, 02:51 PM
Randy WS6's Avatar
whats the spline count on the pinion ? and when you say large pinion bearing are you referring to the Daytona style pinion support
Old 01-18-2014, 12:42 AM
dezlfrek's Avatar
randy I would have to check but it believe it is a 9 and 39 count.. when I say its the big input its the higher splined input therefore a bigger diameter than a standard splined pinion, I am including the hub, the pinion bolt, the housing that is for the bigger pinion/bearings, pinion and ring gears..
dezlfrek's Avatar
randy I would have to check but it believe it is a 9 and 39 count.. when I say its the big input its the higher splined input therefore a bigger diameter than a standard splined pinion, I am including the yolkhub, the pinion bolt, the housing that is for the bigger pinion/bearings, pinion and ring gears..
dezlfrek's Avatar
randy I would have to check but it believe it is a 9 and 39 count.. when I say its the big input its the higher splined input therefore a bigger diameter than a standard splined pinion, I am including the yolk hub, the pinion bolt, the housing that is for the bigger pinion/bearings, pinion and ring gears..
Old 01-18-2014, 11:50 PM
Randy WS6's Avatar
So its a 35 spline pinion, not the stranded 28 spline pinion.
Old 01-19-2014, 10:11 PM
dezlfrek's Avatar
I am assuming you are correct, it is the 35 splined pinion, with a yolk..
Quick Reply: pro 4.29 gears for 9"
