5.3 th400 ebay gt45 build
Old 01-09-2014, 12:57 PM
SPOOLED UP's Avatar
Default 5.3 th400 ebay gt45 build
Yes another
Stock 5.3
Ls9 gead gaskets
Stock 706 heads wuth studs
Ls6 intake stock fuel system
80# inj
Dual 255 pumps
Tu1 cam
Gt45 turbo
Th400 and 3.27 geared
Compressor:
Trim: 69
A/R: .66
Inducer: 68.7
Exducer: 97.8
Turbine:
Trim: 92
A/R: 1.05
Inducer: 87.4
Exducer: 77
Turbine: Outlet = 4" Turbo flange = T4, Downpipe flange = 3.5" V-band
Wanting to run e85 with intercooler and hoping for over 700 ponies
Is this with wishful thinking
Old 01-09-2014, 01:15 PM
2muchboostNY's Avatar
There are a few versions of the Gt45 out there, which compressor size and specs are you aiming for?
Old 01-09-2014, 01:16 PM
Twin turbo c5's Avatar
Oh no very capable of that hp on high boost. I'm thinking your gonna be around 18psi or more to make that kinda power but very doable . Most of my 5.3's and 5.7's have made 600 easily on 14 pSi and meth.
Old 01-09-2014, 02:08 PM
SPOOLED UP's Avatar
Turbo Specs :Compressor:Trim: 69A/R: .66Inducer: 68.7Exducer: 97.8dumTurbine:Trim: 92A/R: 1.05Inducer: 87.4Exducer: 77
SPOOLED UP's Avatar
I will also have to make my kit pipe larger for this turbo to work. Since mine is a 3" vband not a 3.5"
Old 01-09-2014, 02:32 PM
Just curious where did you buy your gt45 and how much?? kinda thinking about trying one on my fairmont.
Old 01-09-2014, 03:30 PM
If im not mistaken Denmah made low 600's in a 4.8L and there was a 240sx with a TH400 that made 700+ using 799 heads anda 4.8...if memory serves me right.
Denmah can give you some real world experience.
Old 01-09-2014, 04:32 PM
SPOOLED UP's Avatar
I will ask em.
My turbo I had from a previous car setup. It was on a older unit.
Old 01-09-2014, 05:13 PM
I-H8-RICE's Avatar
im sure you already have seen this, lol http://www.vsracing.net/catalog/prod...2dc9c26a7cbb6a
idk if they seperate the turbo or not though..
Old 01-09-2014, 05:30 PM
SPOOLED UP's Avatar
It still dont say the specs and downpipe sizing
Old 01-09-2014, 06:24 PM
831jd's Avatar
On 20lbs it will make over 700rwhp but those 706 heads are ganna kill you I bet
Old 01-09-2014, 06:29 PM
SPOOLED UP's Avatar
Well studded and hope for the best. I will get some head later lol
Old 01-09-2014, 06:30 PM
JustAFooL's Avatar
My GT45 showed up today too.. What kind of heads do you recommend? I have a set of factory 241s laying around for the 5.3. Is the compression still to high with them?
Old 01-09-2014, 06:34 PM
JustAFooL's Avatar
I got mine off ebay, DNA motoring was the seller. Arrived in 2 days and was 245$ to the door.
Old 01-09-2014, 07:12 PM
jaywill's Avatar
Interesting to see how it does ...I had the same turbo on a foxbody.. I got the turbo from vs racing
Old 01-09-2014, 07:34 PM
Dang that's cheap. I'm a big fan of on3 but I reallt want to try one of those on my 07 5.3.
Old 01-09-2014, 08:45 PM
JustAFooL's Avatar
Mine is going on an l33. I'd really like to find a build thread on this turbo. It looks bigger than I imagined but I've never had a turbo before so what do I know? :/
Anyone know if battery relocation is necessary or notching the radiator support?
Old 01-09-2014, 08:46 PM
JustAFooL's Avatar
How did the turbo work for you? I've heard nothing but good things from other people..
Old 01-09-2014, 08:52 PM
robsquikz28's Avatar
gt45 is a cheaper version of the BW S475
Old 01-09-2014, 09:02 PM
jaywill's Avatar
i sold the car b4 i finished it... starting a gt45 build on my malibu now
Quick Reply: 5.3 th400 ebay gt45 build
