Super Victor/4150 TB Guys Check In
I'm going this route; I've already determined that. What I'd like to see is pictures of your setup and what all you had to do to your cowl and hood in order to make it fit. Right now, I've got a stock WS6 hood, which I will keep if it can be modified to make everything fit. I'd also like to know if you were able to keep both wipers, only the driver's side wiper, or no wipers at all. If you did have to ditch the wipers, was it because you wanted to, or because there was no way to keep them. Thanks guys, really appreciate it.
You need a filter on there and theres no way you'll fit a filter on there without modifying your hood.
https://ls1tech.com/forums/generatio...law-fit-2.html
Hey bro, There's a dude over on another forum that got away with the scorpion TB i believe and a small autozone filter. He did trim away at the wiper cowl considerably however let me see if I can't find the thread this evening.
Thanks, that would be really helpful. I guess I should go on record and say that I will be using the Scoprion 4150 TB. It provides a lot more clearance than all the others, and still flows a **** ton of air. Like I said, I don't mind trimming the cowl or hood, but would like to keep wipers if at all possible, as the car will need to pass inspection.
From personal experience. Not worth it you don't swap cam over. You will have cylinder fill problems. Talk to Martin at tick. Im Going From Ported Super Vic,4150 To Ported fast.
Later I went to a motor plate and a Custom K-member and lowered the engine about an inch and a half....
at the time there werent any K-members that would allow me to lower the engine, which is why I had to modify the one I had to get lower...
its wasnt really all that hard..just time consuming and I needed a really good welder friend of mine and some extra gussets.
