Iron ls1 turbo plans for TX2K14
I'm cutting it close seeing that tx2k14 is about 2 months away, but I had a 5.3 lm7 iron block that I have bored to a 5.7. I'm really looking for recommendations on my top end parts.
I am about to order a forged ls1 rotating assembly for tsp:
k1 Tech Forged Crank
TSP 6.125 H-Beam with 2000 ARP bolts
Wiseco 3.903" pistons -11cc dish
Clevite main and rod bearings
Wiseco wrist pins
and I'm having them balance it.
Unless anyone has a suggestion on a better cam I was planning on using a COMP Cam Remote Turbo Hydraulic Roller Camshaft K-KIT which includes:
Cam - 235/231 0.621/0.617 115
OE STYLE HYDRAULIC ROLLER LIFTERS
Timing Chain Set
Valve Springs
Retainers
Valve Locks
Valve Seals
Spring I.D. Locators
Magnum Pushrods
My plans for heads were to just use a pair of stock cleaned up used 317 cylinder heads with the springs and valves that come with the cam k-kit. I will eventually get them ported, but I'm thinking they'll be fine stock for tx2k. How much will porting them really help, since I'm going turbo?
And eventually I'm planning to go with a fast intake, but for now I'm going to stick with a stock ls1 intake manifold with stock tb and 42ib injectors.
Planning for 750-800 hp. I've done a ton of research and have seen a bunch of mixed opinions and just want to see if I can get a few more before I start blowing away all my savings lol Any recommendations and opinions will help and are greatly appreciated
Thanks, - Cliff_Z28
Wiseco wrist pins
Timing Chain Set
Valve Springs
Retainers
Valve Locks
Valve Seals
Magnum Pushrods
Thanks, - Cliff_Z28
Is that 750-800 HP to the wheels? If that's flywheel HP, you're over thinking it. That much to the wheels has been made on stock bottom end. Keep the stock crank, run shelf pistons/rods.
80 lb injectors can be found for a little over 300. This combo should be able to push you into 4 digits at the flywheel.
Awesome, thanks for the help
does anyone know a bout geniii and gen iv differences?? https://ls1tech.com/forums/showthrea...1#post17953637
