Electric fan control switch
Looking for a good fan control switch that will fit into the same port as the factory temp sending unit in the heads. What's everyone using?
Painless makes a kit that seems to include a metric switch, but you have to buy it with a harness and relay. They don't sell just the switch. Several attempts I have made to turn down stock switches have all failed.
I was in the same boat, and here is how I solved the problem and stayed on budget. I used 2 of the adjustable temp fan controllers that 89GMC mentioned. I mounted them in a small $5 tackle box and ran the probes into the radiator inlet hose. With 1 controller for each fan I have the ability to trigger 1 fan at a "low" temp and the other at a "hi" temp. I also wired a dashboard switch so I can turn on the "hi" fan manually. So for $35 I emulated a $250 SPAL controller setup! 2500 miles of trouble free operation!
I did find out the hard way that the temp adjustment ***** on the controllers IS LIVE! I grounded one of them out to a wrench once and fried the controller. $15 done the drain... to prevent that from happening again I cut a short length of rubber hose and push it over the ***** to prevent another accidental grounding. Live and learn.
Oh, and of course I have the controllers wired to a relay for each fan. Those F-body fans can pull BIG AMPERAGE and I wasn't about to put those controllers under that kind of load.
I wired mine with a "high temp" fan switched with the aforementioned probe style unit.
Then I wired my low temp or continuous fan off a simple oil pressure switch. Both switched via 88880045 GM fan relay & harnesses.
The fan relays are powered by the same circuit as the MSD so in theory if I loose fans I also lose ignition too.
I have the same setup as the other guys. Works fine. I just have high hooked up to my fans, could do low but I dont see the need. The small adjustments on them are finnicky so just do a little adjustment at a time
Ok thanks for all the info. I think I have come up with a good solution. Derale performance makes a switch #16730 with 1/8" npt threads. Use it with a M12 x 1.5 to 1/8" npt adapter fitting. The switch comes on at 180 and off at 165. They also make one that operates at 10 degrees hotter.
Derale also makes a switch with a radiator fin probe that is pretty cheap. I end up going that way due to a lack of other options and once I set the probe with JB weld putty it has worked flawlessly.
Don't know why no one makes a temp switch for the metric fittings. I would love to have a 200 some degree mechanical one like that as a back up for the high speed fan.
I tapped the top of my water pump outlet for 1/8 NPT and ran the temp sensor for my VDO gauge from there.
Thermostatic switch mockup
Did pretty much the same trick but for my '02 truck. Got me a step drill bit (don't go past 9/16") and a 3/8" npt tap (via Harbor Freight) and tapped the top side of the water pump. Make sure to suck the burrs out of the pump. Hope you can see the pic.
