Oil Pressure problems at Idle or stop
Old 01-15-2014, 12:03 AM
WS6Reaper911's Avatar
Default Oil Pressure problems at Idle or stop
I went in to get my oil change a few days ago and when I left everything was fine for a few miles, then when I came to a stop at a light, my oil pressure just drops down to zero. So I took it back to the shop and they said that I had a leak on my Oil Level Sensor and so I had them change it out. Still, same deal. could it be the oil that I'm running causing this or maybe even my oil pump? I need help, not familiar with the LT1 completely yet. Where should I go from here. By the way, the car isn't running bad at all, and I see no leaks anywhere.
Attached Thumbnails Oil Pressure problems at Idle or stop-20130912_155314-1-.jpg
Old 01-15-2014, 01:25 PM
great421's Avatar
Your Oil Level Sensor (located on the Oil Pan) and the Oil Pressure Sensor (located behind the Intake Manifold) are two very different things.
Install a mechanical Oil Pressure Sensor to confirm your actual oil pressure.
If the engine has normal oil pressure, then the issue is a sensor or wiring; but if the engine does not have normal oil pressure, then the issue is your oil pump.
Good luck!
Old 01-18-2014, 10:53 AM
blade2222's Avatar
You could also try changing the filter and see if that corrects it, might have a bad one.
Old 01-18-2014, 11:17 AM
Inssan's Avatar
Um.... have you checked the oil level?
Old 01-18-2014, 04:04 PM
really? you asked me if i checked the oil level? i said i'm new to the lt1 one not new to standard maintenance. but thanks Inssan. oil levels fine. oil filter has been changed twice. i found a shop to hook up a manual gauge to it already, just have to take it to him. again thanks for the help guys.
Old 01-19-2014, 06:11 AM
LS6427's Avatar
Yup....definitely do this before driving yourself nuts. Cheap and easy.
Old 01-19-2014, 01:46 PM
dailydriver's Avatar
Do the LS1s' oil pumps/pressure relief valves 'like' any certain brand of oil filter, or type/material of ADBV over others??
I use Amsoil EaO 64s, and NAPA/Wix Platinums, and they both seem just fine.
Old 01-19-2014, 02:05 PM
jsteele90's Avatar
just avoid fram filters and you will be fine.
Old 01-19-2014, 03:20 PM
^^^This I knew a LONG TIME ago, except that the Ultras are not that bad, especially for 8 bucks and change at China Mart. OCOD (Orange Can Of Death )
Are any of the premium/top drawer filters better than the others as far as oil pressure goes??
Old 01-19-2014, 03:34 PM
jsteele90's Avatar
ive always had good luck with the wix, ac delco, and mobil 1 filters.
Quick Reply: Oil Pressure problems at Idle or stop
