Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Map lights dimmer switch
Old 01-15-2014, 04:13 AM
TeamSorad's Avatar
Default Map lights dimmer switch
Just curious on the dimmer switch is there a light that is suppose to be there? I have the 2 square map lights and then light around the circle for the sun roof but is there suppose to be a light for the dimmer (white part)? The white starts small on the bottom and then goes fatter. Mine is an 2004 V
You can see it in the middle of this pic, is there a light
https://www.google.com/search?q=2004...le%3B225%3B169
Old 01-15-2014, 06:47 AM
Stone17's Avatar
I want to say yes. I have to hit the switch for the light to come on sometimes.
Old 01-15-2014, 06:07 PM
TeamSorad's Avatar
can anyone get me a picture of what theirs looks like in the dark with the interior lights on?
Old 01-15-2014, 08:00 PM
odthetruth's Avatar
****, had i seen this before I stepped out an hour ago, I would have.
Tomorrow morning, I'll try
Old 01-15-2014, 08:23 PM
Stone17's Avatar
Here you go.
Look like you cant replace that light with out modding it. My light work something but I'm thing of replacing it with a 4mm LED.
The light is under the blue light condom.
Here the 12volt light. You can't replace it. I'm going to remove that light and replace it with a 4mm LED. I'm post more about it later today.
Old 01-15-2014, 09:00 PM
TeamSorad's Avatar
So I have to buy a new whole assembly? Hard to tell from the smallest pictures ever haha
Not sure what you mean
Old 01-16-2014, 06:46 AM
Stone17's Avatar
If you want to. That just a waste of money.
I reposted the picture.
Old 01-16-2014, 06:04 PM
TeamSorad's Avatar
cool thanks for the info, how are you gonna get power to the led?
Old 01-16-2014, 08:18 PM
Stone17's Avatar
How to replace the Dimmer Light.
Parts:
5mm clear White LED NTE300045 $1.63
Resistor $.10
You will need to download a LED Resistor Calc or find one on the internet.
LED calculator:
11.8V Source voltage
4.5V LED voltage
30 diode forward current (mA)
You will need a 270 ohm resistor.
When I did the calculator I got 211 ohm resistor. The high the ohm resistor will make the LED less bright.
Here the part I got.
After removing the old Light. I had two hole to drop the new led in.
I solder the resistor on the positive side of the LED.
I slip the LED into the little hole and solder the back of the board.
Added some tape to the LED and slipped a straw around the LED wire to help hold it (I did not get a picture)
Negative and Positive
Low Dim.
High Dim.
Here a video showing the dimmer working.
Quick Reply: Map lights dimmer switch
