Belt size for new pulley
Old 01-15-2014, 01:42 PM
skydude's Avatar
Default Belt size for new pulley
Chevelle LS engine swap.
Replacing the truck power steering pulley with a smaller one for steering box clearence. The new one is about 1" smaller in diameter. Any ideas how to figure a new belt length? The original belt is a GM 12576451 that to my best knowledge is 93.5".
Thanks for any help.
Bob
Old 01-15-2014, 02:19 PM
superdave84's Avatar
you can run a string around the pulleys and use it to measure. My guess is that the tensioner will make up for that small of a difference though.
Old 01-15-2014, 06:09 PM
i r teh noobz's Avatar
A 1" loss in pulley diameter will only be about 3" of circumference loss, and the belt only contacts a small section. I'd try it with the old belt before buying a smaller one.
Old 01-15-2014, 07:12 PM
Pop N Wood's Avatar
The last 3 digits in the belt part number tells you the length. So the dayco part number for your belt is probably 5060935. You probably need one a half inch shorter or so. So go to autozone or equivalent and get a dayco or gatorback 5060930, 5060923 and 5060920, see which one fits then return the other two.
Old 01-16-2014, 11:02 AM
skydude's Avatar
Thanks guys for the help. I will try the old belt first and go with the others Pop mentioned if it is too loose.
Bob
Old 01-16-2014, 12:02 PM
99VetteFRC's Avatar
I ran a string like previously mentioned, then went to Auto Zone and they measured with a tool and I got the next size smaller. Worked perfect. Got the right belt on the first try.
Quick Reply: Belt size for new pulley
