Filing oil control rings....?
Old 05-10-2004, 05:27 PM
xssive's Avatar
Default Filing oil control rings....?
How accurate do the oil control rings have to be filed? I have seen that they need to have a gap between .015" and .060", but do the two control rings need to be the same gap on each piston? For instance, is it alright to have a piston with one oil ring at .030 and one at .018? Will looser oil gaps result in smoking?
Old 05-10-2004, 06:08 PM
Senior Member
Country Boy's Avatar
No... It doesnt make a difference. Thats why there is such a big tolorance. All they do is scrape excess oil from the walls.
Old 05-10-2004, 06:09 PM
Senior Member
Smoking comes from ALL the rings being worn too much. You still have 2 more tight rings above the oil rings.
Old 05-10-2004, 10:41 PM
LOnSLO's Avatar
To add, the ring size you purchased for your bore will allow you to not have to file the oil ring or support rings, at least it shouldn't. I have never had to file on the oil rings, but I do always check to make sure.
Old 05-10-2004, 10:49 PM
xssive's Avatar
They are just so hard to check the gap on because they are so flimsy. Its hard to square them up in the bore.
Old 05-10-2004, 11:51 PM
Z06PSI's Avatar
Does it.?????? My leakdown passed with flying colors but still get massive amounts of oil consumption and smoke on decel.....Power is good also. GM's weak *** oil recovery rings is the suspect here.
Quick Reply: Filing oil control rings....?
