Question on the Lingenfelter LNC2000
Old 01-16-2014, 03:19 PM
69bigblock's Avatar
Default Question on the Lingenfelter LNC2000
I have a 69 nova with a stock 04 LS1/4L60E. Was searching some good info about nitrous and about this product(LNC2000) which seems great for what I was looking for. So the question is, Are the wires long enough to mount this controller inside the car ? The car ran 12.80 and was thinking of spraying a little....
Old 01-16-2014, 04:00 PM
thahemp's Avatar
Maybe. I can measure the harnesses on mine. I think the 2 coil pack harnesses are 4' long. The control wires are maybe 12" out of the LNC box, then they terminate in plugs that you can attach longer wires to, which it comes with. I put my box on the driver's side inner fender and I was able to wrap the passenger side coil harness around the back of the motor and run up the fuel rail.
Another thing to consider is that the coil pack harnesses have 1/2" plastic loom covering them. Might be a PITA to punch holes in the firewall for that.
Old 01-16-2014, 06:44 PM
69bigblock's Avatar
I'm not to worried about drilling a hole. Can't be as big for the computer harness. Thanks
Old 01-17-2014, 01:54 AM
JDEP162's Avatar
i believe the coil wire connections are long enough, at least to get in to the glove box, on a nova.
Old 01-17-2014, 08:32 AM
M.BOZZ's Avatar
Yes, the coil wire harness is 4 ft long from box to connector.
Old 02-20-2014, 02:30 PM
406chvycamaro's Avatar
Are you going to be running a window switch with the lnc 2000?
Quick Reply: Question on the Lingenfelter LNC2000
