My 02 z28 80mm magnum playin on the street. Also for sale.
This Car made 621 rear wheel horsepower spinning the tires on the Dyno Dynamics dyno 10/12/13 at Revolutions Performance Here in Colorado Springs. The car was Professionally Tuned By Servion tuning using HP tuners Custom 3 bar operating system. We Spent 3 1/2 hours strapped to the Dyno to Get the Tune Spot on. This Car Has a Huron speed non A/c Turbo Kit with an upgraded larger 80mm Magnum xt80 turbo Capable of 1100 Hp. 4 inch thick Front mount intercooler, Custom 3" intercooler cold side piping, 44mm external wastegate, 50mm Blow off valve. Custom Side exit Down pipe. The boost is Currently set to 14 psi with a hallman manual boost controller and is capable of 20+ psi if You Dare! The Car Runs on E-85. The Fuel system Consists of Siemens Deka 80#/hr injectors, Custom fuel lines with a Mallory 1/1 fuel pressure regulator, Dual in tank Walbro 255 lph pumps with dual jegs hot wire kits Feeding each Pump. Cbr Custom alternator Relocation bracket and belt. New intake manifold gaskets, PAC 1218 valvesprings and felpro viton valve stem seals. GM 3.3 bar Map sensor. Borg warner AIT Sensor. It has a 6le deigns gauge panel with prosport boost gauge inovate mtxl wideband air fuel ratio gauge, and prosport fuel pressure. Jakes performance level 2 th400 transmission guaranteed to 800HP, PTC Custom built stall torque converter built just for this setup. BMR transmission cross member with torque arm relocation with energy suspension poly bushing. Custom 3" Driveshaft built by driveline service.17" American Racing torque thrust II wheels and goodyear 245/45/17 tires. The only creature comfort that was removed from this car was the air conditioning to make room for the turbo setup. I'm Sure I'm forgetting some thing but You Get the idea.
The new price you put up should get you some serious people interested. In 2-3 weeks a lot of people will start getting their tax money, and if you haven't sold it by then, then you should have better luck soon after!
Nice car/setup, I think the new price is much more in line.
1 Post
Thanks for the feedback guys. I've come down on the price to $10.9K or a little less without the weld wheels. I have a $700 tune on this car it was tuned by the best in My state. If The motor Does Blow just throw a $500 5.3 in it and be Done lol
