nitrous and breather/pcv set up??
Old 01-18-2014, 03:30 PM
jblankenship's Avatar
Default nitrous and breather/pcv set up??
What are most of you all running? I am currently running a oil water separator catch can with the stock pcv system. I am still getting oil in the intake and on the plugs. I know this is bad with nitrous and I have bumped the jetting from 125 to 175ish for this year. I know what the pcv does vs breather but what is the best way besides a vacuum pump to keep the oil out? My only other thought was someone I read about that was restricting the vacuum from the intake with a valve on the line after the catch can. Any help would be great.
Old 01-18-2014, 04:33 PM
scantone1's Avatar
You can cap all the pcv crap off and throw it away if you want no oil in the intake track. I ended up capping it all then installed 2 10an fittings on each valve cover and set up an exhaust evac on my car. Runs great and no oil. I spray alot more than you and still no issues yet.
Old 01-18-2014, 04:35 PM
scantone1's Avatar
Cheapest thing to do also 30 bucks in fittings and a friend that can weld
Quick Reply: nitrous and breather/pcv set up??
