Stock heads and intake
Can someone please give me some info on the stock 96 lt1 heads?
Good or bad?
Porting and polishing??
Also give me the same info on the intake manifold??
Throttle body?? Better to change it out for a little bigger? 58mm??
Thanks in advance
Sorry for all the posts but i am just getting started on this project and i am trying to learn as much as possible before i make any set in stone plans. Better to do it once than have to put money into something that isnt worth it.
Good or bad?
Thanks in advance
The 571 casting which you might have is generally frowned on forserious professional porting due to being thin. You will need to pull a valvecover and check. If you are saying "port an polish" though it sounds like maybe you or a friend decades out of touch is going to be doing the work and you could give it a shot since you probably wont be drastically reshaping. "port and polish" is 70s vocabulary, polishing is pretty much not done, maybe if someone wants to put the time into the exhaust side but these days most of us who want high end work just choose a good CNC porting shop and leave it at that.
Far as the intake there isn't a lot to be had in porting it but is a decent idea to have THE HEAD PORTER port it at the same time you have the heads done. I would expect your car to likely have the 138 casting intake which has smaller ports that more closely match the heads as cast than the earlier intakes which actually had larger ports than the heads. That doesn't matter atall for porting.
Far as the throttle body, lots of debate on that, if you are aiming for a modest goal though I would suggest a rebored stocker to 52-54mm and avoid the headaches that come with the aftermarket units unless you can buy a used aftermarket that someone already modded to work right.
My $.02 is that with the throttle body their might be some hp gain. Their was a guy on You Tube who did a comparison on a 52mm and a 58mm. The end result was that he gained about 6rwhp from the larger TB. At the same time when he did the dyno comparison he did the 52mm first and by the time he put 58mm on, the car was hot as *****(which = less hp in some cases). But he also had a list of mods to go with it. So if your car is not heavily modded then your results could vary.
I was told by 96capricemanager when I joined the forum that 58mm will yield you nothing unless you have a list of other parts to make you need a larger TB(true)......
Good or bad?
Thanks in advance
Good or bad?
Thanks in advance
Your heads have 561's, which are better stock than the older heads, so your best bet if you are budget restrained is to get a cam that will utilize those heads.
If you want more power then get your hands on the older heads that I posted above. Along with a bigger TB and a ported intake to match.
But like I said, it all depends on how much you want to spend cause it really does snowball.
my 96 also had 643 casting and was a 96. I also ran a 58mm tb on my head and cam car and had no issues with it, however a lot say they aren't needed untill your making a lot more horsepower.
As a lot of us have said a lot of times, all the aftermarket TBs come with some sort of hassles.
Far as the 561s it has long been considered "common knowledge" that they were better but then some of the stock eliminator guys began trying to correct that myth, the stock eliminator guys can not do any porting and found those to be the slowest heads. GIZMO in particular has posted on this. Even said he believed he maybe just got a bad set and tried a couple more sets.
bubee27 everyone here understands what u mean by Porting and Polishing so dont let a narrssist get to u and turn u away. This forum is really not policed at all and several clowns stalk here at will. But there is some valuable help to be found here. Other than that welcome to the forum.
If u want advice on your build u really need to post power goals and most of all your budget. For example getting to 400hp is as simple as a cam and vlv spring change. Going to 500hp will cost 5 times to 10 times that.
Lets hear what u got and what u want,
cardo
cardo
For whatever its worth when I got my car back together I drove it for awhile with the stock 48mm TB. With my tuning software I was able to log the readings from the MAF, with the stock TB I would max out around 340-350 G/sec. I then installed a 58mm TB and ported the inlet of the intake manifold for the larger bores. With the same tune and same MAF mapping I would register 360-380 G/sec and even spiked 390 when I had it on the dyno.
Take it for what its worth but at my power level I did indeed flow more air with a 58mm TB
Unless you plan on having well ported heads and a cam to take advantage of them I would leave the stock TB alone
No more bubee27? No reply in a week! So there goes another new enthusiast just asking for help. It is clear several enjoyed this topic and would like to help. And instead bubee27 receives degrading criticism from u know who. Yes that physiologically dysfunctional self claimed "very knowledgeable" LT1 blogger. U know which sorry azz im talking about.
What a big help,
cardo
What a big help,
cardo
More like welcome to 96crazedmangler. Hes over on another thread now posting his dysfunctional statements: I am sure I have heard of a popular porter porting a set or two and then NOTHING on results which probably says a lot.
Got the OP worried asking: Everything OK at home?
No oversight on this forum here, so the saga continues,
cardo
cardo
cardo
cardo
One thing I can say about 96capricemgr (Dwayne) is he tell it like it is. Raw and Uncut. It's quite entertaining when your the audience but I can't speak for the host, and 90% of the time he's right.
