C5 nitrous guys come on in
For those of you with nitrous on your C5s where under the hood are you mounting your LNC box? We also have a NOS RPM activated box to mount. They're both small and thin but I want to make sure the hood doesn't hit them when they're closed.
If you had pictures that would be very helpful.
Thanks.
Scott
Thanks.
Scott
Thanks guys. Does anyone have any pictures?
Also, I believe I need a power source under the dash for the switch and one in the engine compartment. What are you guys using for these two sources?
Scott
Scott
Add a fuse on a switched source at the fuse box in the passenger footwell to a relay or two powered off the battery works. Really easy to wire in these cars from the passenger footwell to the engine compartment from right behind the battery.
