Tick Performance Turbo Cam....
I have a 3 bolt turbo ls cam specd by martin at tick..
It's a 230/237 117+5 .610/.608
Cam was specd for a 370 and 70mm turbo.has about 300 miles on it and is in excellent condition.
I'll take 300 shipped
Here are some good applications this cam would be suited for:
For a max effort combo that will be able to adjust stall speed and rear gear as needed to compliment the camshaft, the following combo's will work well with this camshaft:
346-376 c.i. with PT7675 or any other 76mm turbo with a 75mm turbine wheel.
346-376 c.i. with S475-S480 with a 83-87mm turbine wheel
346-376 c.i. with S475-S480 with 92-96mm turbine wheel
For vehicles that are more street oriented that cannot modify or alter stall speed or rear gear to optimize the camshafts performance, these applications would work best with this camshaft:
383-408 c.i. with S475-S480 96mm turbine wheel or similar turbo. PT88 etc. etc.
383-408 c.i. with twin 62-66mm turbochargers
hmm, ill be running a 3600lb car, 4.10 gear with 28" tire, 6.0l. was planning either turbonetics 78mm or borg warner sx400 75mm. don't have converter yet so can do whatever stall. street car
