C5 ls1 dbw to dbc
Old 01-20-2014, 08:27 PM
poolsmillrods's Avatar
Default C5 ls1 dbw to dbc
Getting ready to do a ls1 swap for a friend from a c5 vette. He wants it to be dbc instead of dbw. Can the pcm be programmed to operate the iac and tps ? If so who can do it ? I an add the wires myself if it's possible. He has a 700r4 is reason he wants to go cable. It's in a 50s truck that will be a cruiser not a tire shredder. I have Also heard of a special valve body for a 700 where TV cable isn't needed.
Old 01-21-2014, 01:07 AM
1FastBrick's Avatar
Its not that simple. First you need to know which PCM you have. Some years will not support a DBC.
One of the most detailed write up's on the subject I have seen is here--> http://www.lt1swap.com/cable_conversion.htm
Sorry I can't help on the trans side. IMO its easier to use a 4L60E that will plug and play with the set up since your going to need an Input Speed Sensor signal
Quick Reply: C5 ls1 dbw to dbc
