LS camaro radiator, -6an cooler lines and hoses FS
Category: Accessories
Price: $100
Location (State): AR
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Also included New Upper and lower radiator hoses, and enough steel braided -6 an lines and black -6 an fittings to connect the transmission cooler lines to the radiator
This will work if you have a LS engine and the Fbody water pump.
Will do $100 + shipping for everything ....prefer not to separate during this time. Would rather sell everything as a group set.
Like I said the radiator has never had any fluid in it, but it does have some pings on the core itself. Nothing major and shouldn't matter but I do want to point that out so there are no surprises. The pings are on the inside where the fan mounts.
I bought -an fittings to thread into the cooler part, you can see them in the pics.
Here are the hoses, brand new. These will mount perfectly with this radiator and a fbody water pump.
-an lines and fittings. Everything is included to run from the transmission to the radiator. Including the -an fittings that go in the tranny case.
I should be able to get all of this into a single box and shouldn't cost more than $20-25 to ship to lower 48.
