need to know what tranny cooler to use and trans mount HELP!
i will be using a used midwest 3000stall 10.5" lock up converter used for 10,000 miles and 8 1/4 mile passes. i wante dto know what size trans cooler i would wnat to go with? and also what trans mount poly or stock rubber? thanks alot chris
i use the B&M 24,000gvw supercooler
and the energy suspension polyurethane transmount.
the cooler has supported a midwest 3400/2.0, and a yank SS4000
i havent had trans problems yet,
and i drive the car as hard as i can every time i use it.
the es poly mount hasnt given yet,
and that is great considering i am using the TransGo shift kit
with the "three washer" setting
and type-f fluid.
i went through two stock-type rubber mounts real quick with this setup.
(first stock and second one stock-quality)
and type-f fluid.
