Speed Inc now sells Squash Performance fuel systems!
Do you have any more pics of the sending unit ?
The pumps don't look like they are Y'd together prior to the top of the sending unit yet there are still only 3 ports on the top (feed, return, EVAP). Looks like there should be 2-feeds
Can I answer tech questions in here without problems with the mods?
The largest pumps it can take are two Walbro E85 400LPH pumps.
You can't run them from the stock wiring for sure. You'll need a couple relays and breakers, and the 2nd one should be operated from a Hobbs switch if it's a street car.
The pumps' outputs are merged together in the lid part of the unit so there is just one outlet port.
So how low can we safely run the tanks (just freeway cruising) with this kit since the bucket is gone ?
Also is it possible to get a -6AN on the return instead of the stock size ?
