Previous owner problems
Ok so I'm still on the process of returning my car to it's former glory when I bought it there was no shift boot much less the ring I have purchased the ring as well as the new boot however it's my understanding that there is a support bushing directly under the **** to keep the boot from slipping down does anyone know where I can purchase that bushing? Thanks in advance
Save the manuals!
The original boot from the factory was stiff enough to stand up the full height on its own. If you see a bushing on a stick, it's probably a lock nut for an aftermarket shift ****.
Do you have a problem with the boot falling down? If so, where did you get the boot and what kind of shifter do you have?
