Shipping a rear end
Shipping a rear end
For you guys who have shipped rear ends from your home, what do you use to secure/pack it? Who do you normally use to ship them.
I have a 10bolt that I will probably be selling and want it to arrive safely. Pics would be great.
Thanks
Thanks
Super Hulk Smash
You can get a pallet easily from just about any store. Usually they give them away.
You can just strap it to that. Take it to FedEx and have them bitch as you for it being on an open ended pallet. Guess what, I shipped a trans and received a trans that way. They'd have to drop something mighty heavy on it to damage it.
I would then find out what company has a terminal near you. I would ask them what the pallet/crate requirements are.
If you use a pallet it will need to be long enough that the rear does not extend past the edges of the pallet. You can get a cheap banding kit from Staples or similar store to secure it to the pallet. If you decide to build a crate make sure you put blocks on the bottom so it can be moved by fork lift or pallet jack. Normally 4X4 blocks are needed.
Good luck.
Good luck.
for what its worth if you ship it i think your cheapest option is building your own palette to size using 2x3 from home depot.
when i got my s60 from strange it was on a custom palette made of 2x4 and 4x4. i still use that as a ramp to load my snow blower into my truck.
since the 10 bolt is a lot lighter, it would be a lot easier to move. maybe put some cheap casters on one side and a handle on the other so it's easily moved by one person.
my s60 came special freight delivery to my house so it was expected to have a palette jack or fork lift to move it, and the s60 was covered with a heavy gauge cardboard box which really served no structural purpose. depending on how you ship your axle i don't know if the shipper would require the thing to be a complete box or not. if you can get away with just a sized palette using 2x3 to strap the axle to that will be the best way to keep weight down.
